Results 1 to 10 of 20
Thread: plz help dont know what supplies i need first saber
    Wink plz help dont know what supplies i need first saber
    hello these are the parts i have i need to know what i need yet i want full sound swing sensors clash but dont know nething about wiring or what i need to wire .. so this is what i have so far
    x1mhs basic hilt
    x1 av switch
    x1 4 aaa battery pack
    x1 hasbro sound board
    x1 lux III orange/red led
    x4 aaa nimh batteries
    lol that is all i have and i need it to work ... i dont know what i need for transistors or nething like that what is listed is what i have but i can order nething else i need so plz help ... you guys are my only hope
    Quote Originally Posted by th hunter View Post
    x1mhs basic hilt
    x1 av switch
    Hasbro sound board, as in the economy cheap or a hasbro FX.
    If it is the economy cheap, you need a tip42 PNP transistor.
    Is you AV switch momentary? It needs to be momentary for the economy board.
    If you have the FX, it needs to be latching.
    If it is lit, you are going to need a resistor to protect the led in the switch.
    Wires and heat shrink are always good to have.
    Hope this helps.
    __________________
    _Peace is a lie. There is only passion.
    ___Through passion, I gain strength.
    _____Through strength, I gain power.
    _______Through power, I gain victory.
    _________Through victory, my chains are broken.
    ___________The Force shall free me.
    Jedi Initiate
    Jedi Initiate
    equinox13's Avatar
    Oct 2010
    Zama City, Japan
    493
    1
    if you're using an econo board, you'll need a 5V regulator as well.
    what about the hilt parts? are you using PVC or MHS or sinktube? do you have a design in mind already?
    Now known as Azmaria Dei
    lol my im not sure what it is how do u know the difference between latching momentary? it does have the red led ring on it tho and can i wire the lux III to the eco board?
    You need BuckPuck or register for LED.
    If you use Hasbro electronic lightsaber sound board, you need PNP type transistor(TIP42).
    and the hilt parts are all mhs parts i have a idea and my bother inlaw is going to do the powder coating
    thank you guys ... very quik responses kudos
    You should edit your post instead of double posting.
    Check out the diagram on this page for wiring your eco board. http://forums.thecustomsabershop.com...w-DVD-Tutorial
    As far as the momentary vs latching, check your parts list from TCSS. It should show which one you purchased. Other threads show how to wire the AV switch and led in it.
    __________________
    Jedi Initiate
    Jedi Initiate
    equinox13's Avatar
    Oct 2010
    Zama City, Japan
    493
    1
    here's a couple more diagrams to look at with the econo board that i haven't tucked into the main thread yet.
    with recharge port, buckpuck, and lit AV switch
    without recharge port
    the battery can be replaced with whatever you plan on using - in this case 4AAA NiMH which will put out max of ~5.2V and nominally 4.8V - the wiring for the rest stays the same unless you're using a resistor for your LED, in which case you should refer to the main diagram for the main LED wiring.
    Thanks Equinox. I seem to be missing the little things!
    __________________
