10w RGBW using 7.2v battery packs@900 mAh
Is it normal for a purple saber using a 10w RGBW and a 7.2 volt battery pack@ 900 mAh to only have a 36 minute idle run time? The LED is being fully driven (R&B for purple) and the saber is pretty loud and it's wired for FoC, but that shouldn't matter as it was being timed sitting idle...
The first post stated the mAh rating, it's 900 mAh.
It's a RGBW led, the red and blue are on constant while the other two dies aren't doing anything while idle, I'm not sure what current the led is being sent to the led, I'm assuming 1500 mAh as I've seen LEDEngine LED's being run at that current...actually, now that I think about it, I believe I just answered my own question assuming that it is being driven at 1500 mAh.
GOD, I really need to wake up fully before turning on the computer in the morning....
Jedi Master
Actually, I found out it's running the LED at 1,000 mAh, not 1500...so it really doesn't make sense to me...
Jedi Initiate
LedEngin RGBW are rated @700ma
R= 2.24-3.20v
G= 3.68-5.12v
B= 3.20-4.16v
W= 3.20-4.16
are you wired in series or parallel? is it the same for the FoC?
I would think about 40+ minutes or so is correct.. with FoC and 2 dies running together..
whats the problem? are you expecting more/longer?
