Hello Saberland!
With all the hubbub about the new SWTOR game to soon (hopefully) be released, it is natural that people (including us ) find inspiration in the concept art for the game. Nartules, one of our best customers, contacted us several months ago about creating his very own Crystal Focus powered lightsaber. He had seen a saber in one of the concept shots and made some tweaks to the rear grip design to suit his own desires. Here is the original and modified concept drawings. Full size versions can be viewed at the SWTOR site:
One of the features that stood out the most to us was the very prominent control box. The original design showed light coming from the top, and with the winglets at the front visions of bargraphs and low profile switches began dancing in our heads ;D After careful design on the box to make sure that we could fit everything into the saber to make it functional we went to our resident Acrylic Master, Arkai Halon of Halon Customs. He is responsible for our very sweet stands as well as custom doodads like this awesome box top here. It is made of mirrored acrylic with the center section directly above the bargraph lased off leaving a nice frosted diffused window for the 7 SMD UV LEDs to shine through.
The inside of the box where the winglets are was made to have 2 momentary tactile switches with the plungers poking through. We decided as we got closer to completion that plastic switch plungers had no place in this design. We wanted a more finished classier look. So borrowing (some may say steal, but I won't listen to that crazy talk ) the idea for aluminum switch hats from our Starkiller run (Thanks Ace!) I machined little hats for the the tactile switches so that it finished off the outside of the box. Verrrry niiiiiice
The emitter is also a very obvious feature of the saber. It has large vents around the tapered ring with the windows shaped like trapezoids to help tie in the shape of the box. They are REALLY cool for letting the blade light to shine through.
The rear grip was the main modification the Nartules made from the original design. He changed it from the raised, Vader/Starkiller style black bars to a more streamlined comfy grip of milled strips.
Helping to set off the whole design, we have bonded black chrome powdercoating on the necked area as well as the rear grip slots and emitter grooves. A bit of light weathering was added to the hilt to really make the subtle details of this saber pop, and to give it the "used tool" look rather than a stand queen.
This saber also sports a brand new fresh off the toaster Crystal Focus V5. We couldn't wait to hook up the V5 as it gives us a whole new playground of features to play with. Most visible of those is the new 7 accent LED pads that it sequences. They aren't just pretty either, they're functional now with the new PLI (power level indicator) feature to give you a gauge on the remaining battery life. They also will tell you what font number your on as you're scrolling through the menu. In addition there are also new LED sequence mods for idle and lock-up displays. Other new surprising features of the V5 is the new audio amplifier which delivers a new level of clarity and tone to our lightsabers. All the fonts/boots are SOOO clear and there is even some added bass to everything and still SOOO tight with no distortion audible. The alternate power on/off sounds are also great fun and add some variety to the font itself.
Quick Specs
Custom machined hilt based of SWTOR concept drawing
Pyramid control box with SMD LED bargraph and tactile switches topped by custom acrylic strip
Heavy vented emitter
7 segment UV SMD LED bargraph
Bonded Black Chrome Powder coating
Light weathering
Crystal Focus Sabercore Version 5
10 Watt LEDengin RGBW mixed for OSPPŠ
Green and White dice set for FOC (Flash on Clash
7.4v LiMn battery pack with recessed in hilt recharge.
Pics:
Video:
http://www.youtube.com/watch?v=6D8S9ZkA4eA
