I did some more use of this compler while building my staff.
I've noticed 2 things that I can add to my feedback:
- The amount of play when attached is greater now that have the coupler mounted on the staff... the weight of the other MHS peices thus increases that play.
It is a bit weird having that play when moving the staff, both saber parts (made of emitter/choke/ribbed section/3"extension) now clearly move when coupled together.
- One of the button doesn't fully come back up anymore when I attach both parts. I didn't do anything special to the coupler (yet), that just happens now... I think this has been mentioned already, but I wasn't going to read that thread over again ^^ So I mention it here. I think it is slightly twisting inside and it prevents the button peice to go back to its original position.
Now I also confirm that it is almost impossible not to cut my big fingers when detaching the coupler. But I'm thinking about a workaround for that one, using rubber peice or athumb screws, I'll eventually test that later.
Out of curiosity, Tim, do you have an idea when the second version will be released for tests?
