yoda 2010 econo board with sensors - had to resolder EVERY connection on it and replace half the wires... they kept popping off... i also wired it separately - the LED wires are going to the AV switch LED and the button on the bottom turns that part on and off
built a power pack from 2 Li-Ion 18650s from a dead laptop (new PCB)
Seoul P4 and a buckpuck 1000 driving it
on the bottom rubber O-ring there are 3 sound holes for the speaker right next to the switch
the MHS parts should be self explanatory
learned a lot about cram-fu
^_^ bottom line is, it all fits, all works, and i will hopefully never take it apart again. the exterior won't be complete for a bit longer though - i need to get some chord to wrap the handle in.
***edit - adding a pic with the wrapp around the lower handle. i used 550 cord in that new army uniform color, whatever they call it. ^_^
