ok. i talked to a few in the shout box about this issue and nobody can seem to find whats wrong. my problem is. no matter what voltage input. i never can get more then 2.2v at the LED.
here are the layouts and pics
in this pic the resistor is glued on the back of the board and the transistor connects to it trough the hole in the middle of the board
oddly voltage tested on the LED + is just fine. same as battery +. but when i go testing any other voltage using the -
ground from the LED- i get voltages WAY short of what they should be. only get .6v testing the main + from battery against it
anybody know what the issue could be? only thing i can think of is a bad board and forced to find another means
of lighting up my LED effecntly. first i thought heck. maybe more input voltage = higher output voltage. so i
swamped out the 4x 1.2v rechargeables for 5x alk batteries 4x in the 4 holder and added a single cell holder for
a total of 7.5v input. and STILL only get 2.2v at the LED even without a resistor!
