Ari,
I honestly don't know. I don't know how the hasbro boards work. He could try it, but it's only 99 cents for a 5 pack of resistors from Radio Shack vs. $16.00 for a new AV switch with a working LED.
Ari,
very true ill try it and let u know how i faired out
Try not. Do or do not, there is no try.... Yoda
THREAD INDEX
LDM's Basic Saber-build Step-by-Step Tutorial
got my wiring correct now ....wired pos and neg from switch to board ....flickers when struck ...very cool ...
THREAD INDEX
ok other question since we are talkin about av switches here ....if have a latching switch with no sound board how do you turn the switch led off when you turn the switch off
THREAD INDEX
the AV switches are DPDT - do you have anything wired to the second poles? you could wire the LED through that so that it turns off when the switch is off.
For that set up it is easier to just run the same wires for the main led and just resistor the negative to the switch led. As described here. You can also replace the buck with a resistor for the direct drive.
*puts away spoon*
