Results 1 to 10 of 18
Thread: Jin Starkiller's "dark solace" (MHS with resistor driven LED)
    Default Jin Starkiller's "dark solace" (MHS with resistor driven LED)
    New saber i am working on it is dark solace and is a sith saber
    lux 3 red
    3.3 resistor
    lens holder
    lens
    dpdt momentary switch
    bezel
    150ohm i/4 watt resister
    4AAA battery pack
    2010 obiwan sound board
    blade holder style 1
    double female
    double male with slots
    7" fluted main body
    mps pommel style 8
    insert 7
    4 footman loops
    flange from a 1.5 sinktube
    crystal chamber
    covertec button
    just want to make sure i didn't miss anything
    Jedi Padawan Ronan's Avatar
    Jul 2010
    Montreal, QC
    529
    You forgot to pay Tim, but thats about it
    Oh and a covertech screw and a C-Clip.
    Corbin_Das: If I got a tattoo below my waist, it'd say "Found someone you have I would say, hmmmm?"
    i've got those already and i think i gave Tim more than his mortgage payment this month with 8 orders..
    here some wip pics
    ok here the update
    got almost all my parts now except for the female coupler should be here this week
    I've always loved that emitter-style. Looks awesome.
    thanks ever since lightsabers from the big yellow box i can't stop using it ..looks unique compared to other emitters
    maybe take it up a notch..
    use hex head screws and then use a smaller diam. drill bit to drill 'through' the hex/screw stem...
    this will let light through the holes.
    do it for both top and bottom?
    or maybe just every other one? to keep some 'strength/support'.
    Jedi-Loreen's Avatar
    Dec 2005
    Not of this Earth
    6,077
    They also make vented socket cap screws that already have a hole through them. But they are comparatively expensive at ~$1.00 each.
    thanks for the information ....didn't know they made them with predrilled holes through them will have to look at that for the next time i use this style
    Jedi Initiate
    Jedi Initiate
    equinox13's Avatar
    Oct 2010
    Zama City, Japan
    493
    1
    personally i think you should stick a ring of older solar cells around the emitter. it would give it a nice fresh electronics age bit of flare.
