Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 47 of 47
Thread: seoul p4 reds
  1. #41
    ok so i don't need the resistor is that what you are saying....first time using rebels
  2. #42
    Quote Originally Posted by jin starkiller View Post
    I don't suggest anyone directly power an LED from a un-resistored battery pack. Some people do it. I don't recommend it.
    You need to add power to your battery solution, and then use the proper resistor.
  3. #43
    Jedi-Loreen's Avatar
    Dec 2005
    Not of this Earth
    6,077
    Even with no resistor, a 3V battery pack is not enough voltage to properly power that LED.
  4. #44
    ok so go up on my voltage got it ...thanks
  5. #45
    Regarding the use of a resistor with the red P4, the store suggests using a 4.7 ohm/5 w resistor...but here I read to use a 2.2 ohm/5w resistor. Which resistor would be the better choice for use with the red P4? I wanted to do a LUX III conversion on my older MR saber (3 AA batteries putting out 4.5v) but since LUX III's are no longer to be found, I suppose I wil use the P4 but want the correct resistor.
    Quote Originally Posted by Shadar Al'Niende View Post
    I have not used a Rebel as of yet, but looking at the specs the lumen output is comparable. The P4's forward voltage is only 2.5 and the Rebel is 2.9. So the P4 seems slightly more efficient. As I have recently learned however the P4 is a little more um.... fragile. (i blew one by not using a resistor despite knowing that others have done so with no issues)
    Keep in mind that you will need to order a heatsink shim, lens holder, and lens made specifically for use with the rebel in MHS.
    For the P4 (and possibly the Rebel) I would use the 2.2 Ohm 5 Watt resistor sold in the store as well...
    Good luck, let us know how it turns out!
  6. #46
    Jedi Initiate
    Jedi Initiate
    equinox13's Avatar
    Oct 2010
    Zama City, Japan
    493
    1
    if you're using an MR board, you'll have a constant 3.5V 1000-1200mA coming off of the LED wires on it. to cut that back to a level that won't explode your red P4, you need either a 1 ohm or 1.2 ohm resistor, depending on what your board output is (1000 or 1200mA).
    Now known as Azmaria Dei
  7. #47
    Yes...I do plan on using the origional MR board with my conversion. I'd hate to toast the P4 without the proper resistor.
