Asajj conversion
so has anyone ever taken apart the saber if so is there any possibility of Tim making a conversion kit?
Force Aware
Im not sure but it might happen...Tim helped me out with this but I dont want to say anymore. Thanks Tim!!
Dammit, I wrote a guide for you to follow. Browser ate it.
TL;DR version.
Remove endcap, remove 2x phillips head screws. Drill out metal plug on underside of hilt, remove 1x PH screw. Drill out hex socket screws in ribbed section and remove. Difficult to hold still with allen key, glued in - drilling out head was only way I could get them out. They go right through hilt and blade.
Under the ribbed section are 2x PH screws (I think*). Remove them then slide flanged emitter housing along blade axis, may need to lever it a bit, they threw epoxy all over the place on mine. (*they might be under here instead. I'd already broken my hilt by this stage. I'll check the bits tomorrow.) When that slides free, hilt halves can be separated.
Other people have suggested the dooku kit for the conversion, it'll take some dremel work on the inside of the hilt to get it to fit properly.
I'll take photos tomorrow.
Dave
