Originally Posted by
Rhyen Skytracker
Series would be going from the Batt + to 1 LED +, from that LED - to the next LED +, from this LED - to the batt -. If the LEDs are 3 Volts and 20 mA, that will use 6 Volts and 20 mA. If you wire them in parallel it would be the batt + to ALL the LED + and the batt - to ALL the LED -. If you are using 2 LEDs like in the series example you would only use 3 Volts and 40 mA. So, a series voltage will require a lot more voltage but only use a little current and a parallel circuit will use the Forward voltage of the LED and the current use would be the sum of all the LED currents.
