Force Aware
Finished my crystal chamber today. Well, the guts at least. I may go back and paint, or swap out the heat vanes in the future.
The vanes are starting to show some slight surface rust, which I'm actually liking. I may weather the whole saber in this theme. If I can work out weathering!
To finish the chamber, I had to make some crystals. I had some plastic swirly red pen blanks which did the job nicely. Whacked them on the lathe and turned them to shape. Yes I know most crystals are not round, but these ones are
I drilled holes in the back of them to mount LED's - the crystals themselves now glow internally.
I was going to thread them to screw them into my pommel inserts there, but I suck at threading, so I drilled the inserts out and fitted the crystals to the slightly bigger hole.Would you believe they're being held in place by masking tape?
I fed my wires through the holes drilled in the back of the heatsink vanes last night, and started soldering today.
See in here the brass cylinder holding the bottom of the chamber in place? The length of that shaft is all I had at the top to connect the lux and the top LED for the chamber. Cram-fu much? I know some of you have done better than that though
So as it stands, all that's needed is the hole for the anti vandal, and some more wiring, to complete the saber to a "useable" level. There's more embellishments to come though, if I get brave enough with wiring.
Force Aware
Not bad! I like the layering, although I think the heatsink would look better on the other side as to expose the crystals more. Also it looks like the crystals you made are round with points. I've made my own with plexi-glass on a belt sander and they looked pretty good. I sanded and filed them to have streaks and fogging to diffuse light. The crystals look a bit far from each other and you still have a hole in your pommel insert....could be useful or a nice spot to add something cool looking.
Off to a great start!
