Results 1 to 10 of 10
Thread: how long should the blade be?
    Default how long should the blade be?
    just wondering because im wanting to duel with my fan force members and they all have parks sabers
    Oct 2005
    3,502
    Parks blades are 40" I believe
    yes they are
    but 40" blades are...floppy. If you mean how long should the blade be, do you mean for your dimensions or what? In the movies the blades look around 30" but I didn't make the props so...
    ok but
    how many times do you loop the the el wire on a 40 inch blade?
    because you gave me 17' of el wire
    Oct 2005
    3,502
    5 times..
    40" blade.. minus about 1" for the mono plug = 39"
    39" x 5 strands = 195"
    195" divided by 12 = 16.25 feet
    Thats why I include 17 feet of wire.
    So how long is an ideal blade? In the movies, it's 39 inches (1 meter), but apparently those flop around a lot. So how long can I make it without it being floppy?
    Oct 2005
    3,502
    33-36" is a good length
    I really have no problem with a 40 inch blade
    but im very tall 6.6 and long armed
    it all comes down to body size some of my dueling buddies have 30 inch blades.Just go with comfort
    look at yoda little blade kick ass potential
    Darth Albeehotep[][]
    Peace is a lie there is only-- Passion!
    Through passion I gain-Strength!
    Through strength I gain-Power!
    Through power I gain-victory!
    Through victory my chains are broken !!
    i set my length so that the blade from the tip to the emitter is 36 plus whatever goes inside. so lets say, tims holder is 2 inches and its flush with the end my blade would be 38 inches not including the mono plug.
    I built a set of Dueling El Sabers(3/4"Th.) that have a 40" Blade Length and have even fought against a Shanai without any problems, but I am currently building a Led with a 1" Th. Blade and will probably go bettween 32"-36" to be more screen accurate.
    May the Force
    Be with You
    Marc E.
