As announced I started building a better chassis. I used the chassis disks from the TCSS, a plastic panels, threaded rod and some tubing. I know, the slots in the disks are not cut cleanly but I just wanted to make a prototype to test whether my imaginations could work. Another problem is, that I took the wrong chassis disks. I took the bigger one which normally should be between different MHS-parts. So I cannot put this chassis into a saber.
Here you can see the status quo:
I will try the same construction with 14650 li-ion batteries as these have the size of normal AA batteries. I hope I can put the board on the batteries instead of behind them.
Comments and tips rqeuested
