I was going to vote for sticky too, until it got stickied, very informative CC!!!
I believe aerorocket is right about the graflex pins. The same question was asked here as well: http://forums.thecustomsabershop.com...lectrical-pins
As for the tool to install them, I found that a small piece of aluminum spacer (chassis disk spacer) works GREAT! Just stick the head of the pin in the little spacer tube, and use it to screw the badboy in, applying a moderate amount of pressure downwards. The aluminum is just soft enough to grip the hex heads well and screw them down snugly. Found that one out when my clumsy fingers had dropped the damn graflex pin while trying to finger tighten for the ninth time. Those things are TEENY!
Acerocket is correct (shocker? ) The G-Pins are indeed 3-48. I didn't have a small enough socket to use so I just used some fine-tip needle nose pliers to tighten mine down.
To drill and tap, you will need a #47 bit (.0785") and a 3-48 tap.
-Takanis-
Simpi-Gon Sims (FX-Sabers Forums)
Anyone know the tap size to this?
Olc-Pa Mabec
Looks like the 5mm LED bezel from the store.
If it's that one, then it's listed on the first page:
If it's something else, I don't know how to get you the thread information from just a picture.For the 5mm LED bezel
- To tap and thread; M8x0.75 metric tap & 7.25mm Drill bit. 5/16-32 tap is not compatible with the Bezel
I am not sure if it is the one from the store, since i got it at radio shack but i will try that tap size see if it works thanks silver serpent
Olc-Pa Mabec
AWESOME! thank you very much Sir. That is good to know, cannot wait to get it set in my saber.
Olc-Pa Mabec
Sorry, but what does countersink mean?
