Results 1 to 8 of 8
Thread: Led upgrade question
    Default Led upgrade question
    Ok I searched for about 3 hours last night and just got more confused as I did so I'll just post my question here. I am upgrading from a lux 3 (blue) to a less seen lux 3 red orange. My curent set up is using a MR FX board running off of 4.5v the specs for the blue is 3.9FV @1a but the spec for the red/orange is 2.95fv@1.4a so what I'm trying to find out is can I run the red/orange off the fx board? Just a simple swap? Can the led Handel the higher voltage? Some of the post I saw said they could some said no otheres didn't specify.
    Any advise from some of the more seasoned vets? On a side not I was thinking of running 2 700ma buckpucks in between the board and the led to get the 1400ma I need if this won't work either pls some one stop me now!
    Thx
    The red-orange will easily handle the extra voltage. I have that sort of setup right next to me.
    Though it will not be as bright as if you would drive it with 2 700 mA pucks.
    I don't think you can use buckpucks with MR/Hfx board due to their low LED output voltage. The pucks need at least 5 and MRFX boards put out about 3 volts. (Just multimeter'ed)
    Rafalema u are a lifesaver! That's the info I was looking for.
    Always happy to help.
    Rhyen Skytracker's Avatar
    Feb 2009
    Covington, GA
    2,550
    If you are looking for a red LED that will work great with the MR/Hasbro FX board try using a P4 Red. I have had great results with those.
    Lord Dottore Matto's Avatar
    May 2008
    On the Black Mat
    3,289
    That MR board puts out ~1A which is fine for your R-O. It will not be maximally driven, but I doubt that you will notice a difference (to the naked eye) since the R-O's are VERY bright. You could use the pucks if your battery solution were 6V, but like I said, there is really no need.
    Thx everyone for the great feedback. I think I'm going to just keep my curent setup(running just the fx board to drive the led) and swap the blue for the R/O which is what I was hopeing I could do.
    Banned Sith Lord
    Feb 2009
    1,873
    posts pics when you is done kk?
