Hello guys. This is my first post. This is a great forum and I have learned a lot. I just have some questions:
I recently purchased a graflex blade adapter for my replica graflex saber that I got from the shop here. First of all, the blade adapter was much to tight to fit a 1 inch blade into it (I ordered the LED Graflex blade adapter). I had to do a major amount of dremeling on the blade to fit it into the holder.
Next, the small screw hole on the bottom side stripped out rather easily. No biggie, I just re-drilled it and re-threaded it for a 8/32 screw. Is the aluminum really soft? I didn't even screw it in that tight.
Next, I went to screw in my replica glass eye blade retention screw, the hole in the adapter was off set from the middle of the hole on the bottom side. I had to do some dremeling on the graflex to allow the screw to fit into its slot. Now it fits in, but there is a gap on one side of the screw and you can see under it and the other side it sits flush. The adapter is in the proper spot inside the graflex so it isn't that it is mis aligned or anything.
Lastly, the adapter has some play in it. If you handle the graflex saber and give it a wiggle, you can feel the blade wiggle. Or more accuratly, the adapter wiggle inside the graflex which in turn makes the blade wiggle. The blade is tightly screwed into place in the adapter and there is no wiggle room there, just the adpater itself is wiggling inside the handle.
Are they all this way? I was under the impression it was a solid piece that you could use to duel with, but I don't think I trust doing much with this other than displaying it. I also built a MHS saber replica of Obi-Wans saber and it is rock solid. I can easily duel with that saber.
The graflex saber itself came out great. It is very nice looking and I couldn't be happier with how it looks. I did a simple LED only build with no sound effects. I put a little switch on the lower bottom side and it is nicely done. Thanks for any responses ahead of time. Any tips on how I can make this more solid would be appreciated. Not really looking to glue it in or anything, just in case I have to replace the LED, I want to be able to get the blade holder out again.
Thanks.
Here are some pics.
