Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: PLI Mounting Solution
    This is what i am doing for mine. 6-32 screw grabs the rubber grommets nicely. the front screw will be trimmed. The rear screw presses the bottom of the box to hold the faceplate in place.
    What box is that TW? And what did you use for the faceplate? I am intrigued
    I got it off an old Parks. But its very similar to box style5. I made the faceplate out of a small piece of brass scrap i had.
    I don't know what size a graflex clamp is, I've never used one. This particular one is 2.25" longand the PLI is somewhere around 1.75" long if i remember correctly.
    The dimensions of the PLI from the store state:
    Dimensions: 1.69" Long x .43" Wide x .33" Thick.
    Does anyone know what the width is on a box 5?
    The flush mounting option that was mentioned earlier may be how i want to do it as I want the hilt to remain as sleek looking as possible. thanks for the 6/32 hint TW!!!
