Results 31 to 35 of 35
Thread: eastern57's lighthound momentary to latching switch mod
  1. #31
    I have used these Lighthound boards on several builds and found that on occasion it would not work until I reversed the leads for the switch, not sure why.
    I also suspect that micro bridges are forming during the soldering phase.
    best,
    -AV
  2. Default
    Just to confirm because I'm not sure if I am able to get light hound on my side of the globe but the flashlight just has to be the type which goes out when released?
  3. Default
    Yes, but as stated earlier, you're better of getting a Pololu board.
    Also, holy necro batman
    When your lightsabers gutter and die in your hands,
    your blaster packs run dry of charge,
    your words of power dry up in your throat and I am still standing,
    what will you do then?
  4. #34
    I accidentally bought a momentary switch instead of a latching one. I'm not really interested in spending more or in waiting another few weeks for a latching switch to get shipped to me. For my project I'm not using a sound or control board. It's just a straight circuit. Is there a way to convert the momentary switch to a latching one without the control board? If so, how?
  5. #35
    You can hold the button down. Any other solution is going to be more expensive and time consuming than ordering a new switch.
    http://led.linear1.org/1led.wiz for all your LED resistor calculating needs!
