So I have had a lot of people ask (and seen posted on the boards),
"How can I make a cheap but cool saber?"
The answer is usually...this isn't a cheap hobby and there really isn't a good way to do it. I might have an idea that I am going to try.
It begins with this item:
Bayco LED Flashlight SLR-2380
Usually sells online for $15-$20
Possible total cost:
Flashlight $15-$20
New LED $8-$10
Blade/tip/etc ~$15
It's realistic that you could put together a decent looking, stable saber for ~$40 depending on what you needed exactly.
-Flashlight: 1 Watt (25 Lumens)
-Floodlight: 30 LEDs (60 Lumens)
-Rechargeable
-Impact resistant ABS case
Now the floodlight effect is very cool and can be left alone or maybe put a colored film on the inside of the plastic shield for color effect, I am aiming to replace the "flashlight" led which is white 1 watt to one more commonly used for sabers like a P4 White LED.
When we open the flashlight up (very easy to do just by removing 5 phillips-head screws. Here are pictures of the innards:
I find that is is organized very well and laid out great.
Here is the connection for the single LED board which should not be hard to replace.
The nice thing about this is all the wiring for switch and charge port is already done! The button when pressed has 3 tiers.
1 Press - Flashlight only
2 Presses- Floodlights only
3 Presses - All Light
The width of the opening is 1.25" across, so finding a suitable blade holder shouldn't be that difficult.
Any other suggestions or ideas are welcome, will update with finished photos when done.
