I am somewhat confused by this LED and need help to wire this up for purple...
The specs are as follows:
It looks to me that the R, G, and B have a + pad but its a common neg pad on the bottom right. Soooo.... If i was to use one of these with a cheapy hasbro board (no poof <= 6v) my power options are a little tricky. I could use a single 18650 and wire it parallel (this would halve the 24000 mAh rating between both led's giving them roughly 1A ea) OR, i could use a NiMH solution for 6v, and wire the Blue and Red in Series with the Red last.- Seperate input wires for Red, Green and Blue allowing customization of colors
- Driving voltage and current per channel:
Red: 2.5V ~ 3.0V, 350mA
Green: 3.2V ~ 3.8V, 350mA
Blue: 3.2V ~ 3.8V, 350mA
- Note: each color channel is able to take a maximum of 350mA of current, thus a 1050mA combined current input and the 3W rating.
Here are my concerns....
1. If wiring in series, will the voltage split damage the blue die? Has anyone done this specifically?
2. If wiring Parallel, would i simply splice the board pos --> led pos so that each +pad gets a lead going to a single lead off the board? Do i use the common neg by just running this to the board?
3. Will the board run ok off of 3.6-3.7v?
I am leaning toward the NiMH solution personally for various reasons but if its not do-able that way...
Thanks in advance guys!
