This will cover the complete build of Chrome Saber 25 (CS-25) from start to finish. I'll be using a simple non-sound resistored set-up for this saber, and will be cutting a chrome sink tube sleeve for it.
Here's the basic render:
The Parts:
Parts list:
- MHS blade holder style 12
MHS ribbed extension; powder coated in RIB3 style
MHS hilt style 2 w/guarded switch hole; powder coated in SH22 style
MHS pommel style 1
7" chrome sinktube; 1 1/2" O.D.
Machined covertec button; black anodized
8-32 x 1/4" socket head cap screw
illuminated anti-vandal switch w/blue ring; 12v led (not from TCSS)
Machined bezel for anti-vandal switch
4 AA (6v) battery pack
Seoul P4 blue led
5 degree lens
Luxeon III lens holder
3.3ohm, 3watt resistor
quick-disconnect plug
This saber shouldn't take too much too long to build! I got started on it yesterday by cutting the chrome sink tube to length, and as soon as I cut it, I realized I had goofed....I measured it wrong so it was un-useable. I had wait until today to go to the hardware and get a replacement for it.
So, after screwing up the first chrome tube I cut for the half sleeve for this saber (I measured it at 6" instead of 7"....D'OH! ) I cut the new one to length and used my rotary tool to de-burr the part:
With the sleeve deburred, I laid it out next to the hilt and checked to see where I'll have to cut it for the grip window:
I then marked it off using a black Sharpie:
And using masking tape, made the pattern I'll follow with the cutting disc on my rotary tool:
I set it up in my drill press's vise:
And started cutting:
I always follow the direction of the cutting wheel, so in this case, I had to move from right to left to make these cuts:
To remove the un-needed piece, I'll cut across the corners at an angle:
The black thing in the corner of this picture is the end of my shop vac's hose:
I use it as a dust collector when I'm cutting tubing....helps keep the mess to a minimum, and I breathe less dust that way. I also use a dust mask and safety glasses, as well.
There's more material to remove from the corners, so I'll continue with the cutting disc on the rotary tool, and just get what I can with it:
Done with the cutting disc:
I'll change the disc out for the 5/8" sanding drum attachment so I can round out the corners:
I use an oscillating motion when I do this, to even the wear on the sanding drum. Otherwise, I'd get a single worn strip on the drum, and eventually a cut. Work the drum into the corner until all the material is removed, and you have a nice rounded corner:
I did all four corners:
To further straighten the edges of the window, I'll use a hand file for metal:
This may require the removal of extra material depending on how steady your hands are when you cut the window out, and how straight your cuts were. I had to go back to the rotary tool with the sanding drum to even the corners out again after I was finished filing.
With the filing done, and all the edges looked straight, I went over the widow's edges again by hand with some 400 grit sandpaper:
After that, I went over it again with a piece of 800 to really smooth it out.
Here's the finished sleeve with the hilt section:
And test fit:
That'll work!
