Five AA batteries!
Firstly, thanks for the LED, driver and emitter assembly. The wiring diagram on this site suggests five AA batteries for the Luxeum and driver board. Can you suggest a way to mount five batteries? If I used a 9V battery instead how could I reduce the voltage to 7.5 volts for the board? Would sticking a small LED in the way do this or would I need another resistor, if so what size? As an aside, how do you stop all the electronic parts from rattling around inside the hilt?
Duct tape is like the Force: it has a dark side, a light side and it binds everything together.
Duct Tape is like the Force: it has a dark side, a light side, and it binds everything together.
You could get a 6 AA holder that stacks the batteries like so.
12
34
56
Fill all of the slots with batteries except for the "1" slot. Instead of a battery, put a piece sof small wire or other conductive material (such as a small bolt) from the spring to the small dimple. That will give you 7.5v.
Either that or find a way to fit a 4AA holder and a 1Aa holder n series in the hilt.
As for the rattling problem, most people just stick some foam, such as pipe insulation or from a pool noodle, around the parts to pad them and keep them in place. Even just wadded up tissues or toilet paper will work.
phat lewt=kash munni
It's also posible to get a 4 AA holder, and attach a one AA holder to the underside with hot glue and wire them together. It may need some minor shaving to fit inside the tube.
You can also but tiny connectors (like plugs) to avaid having a tangled bunch of wires. it takes time, but what a difference!
MC
Sith Acolyte
i was wondering tim said that 9 volts dont have enough current for the 3 watt leds can someone explian the difference between current and voltage and also why are the 4aaa battery packs baetter than a 9 volt. sorry if this is a little off topic.
"aaah general kenobi you are a bold one."-general grievous
Sith Acolyte
so what do you recomend for 3 watts? 5 watts?
<font size="6"><font color="red">AAAGGGGGGHHHHHHHHH!!!!!!!!</font id="red"></font id="size6">
Is this for real?
<center></center>
Sith Acolyte
thanks i get it know ill just stick with 4aaa with the 3,and 5 watts. maybe 9 volt for the 5 watt.
thanks x wing.
Definitely go parallel 9v for the 5w. The difference in brightness is very noticeable.
My collection:
02' MR Anakin AOTC
05' MR Anakin ROTS
05' MR Luke ROTJ
06' MR Maul TPM
MHS 5w Luxeon(RylBl/Grn)
