It depends on how much voltage is actually going to the LED, what the forward voltage for your LED is, and how much, if at all, you want to over-drive it. First, measure your voltage. The multimeter is your friend. Then check out
the handy Resistor/LED Charts that newcomers all seem to overlook. Rule of thumb: you are more likely to need a resistor if you are using a red/orange/amber LED than if you are using a green/blue/cyan/white LED.
Living in Japan, I don't know beans about RS, other than that it has one foot in the grave. (See earlier post.)
"The Google" is your friend. "TIP42" and other transistor numbers we give here are generic names for transistors of certain types, and are manufactured by many different companies (mostly in China, using children who are chained to the assembly line and force-fed lead and mercury twice a day). So using these numbers to find the transistor you need is easy. Unless you live in North Korea. In which case you wouldn't be participating in this forum. Unless you were a government agent.
If you can do without one, yes. See above.
Like I said, it depends on all those different factors.
After typing all this, I noticed that you have been a member since 2006. No offense intended, but, based on your questions, I thought you were a newcomer.
