This is the wiring schematic I'm using right now.
I tried using the relay without the PNP transistor, but the problem with this particular relay is that it needs 600 mA to activate... so I had to come up with something in order to get it to switch. Now if you have a different relay or one that can switch on low voltage and current, then you might be able to forgo the transistor. I actually ordered a few different ones to play around with, but they haven't gotten here yet.
Please note - this is NOT a recommended setup right now.
I'm going to experiment with a few things in order to try to get the LED to flash a bit brighter.
-C
