hi all,
this is my new parts list so far for a new saber, thought i'd post it and get some advice before buying again.
any thoughts and comments are much appreciated, cheers
Luxeon III (amber)
MPS pommel style 6
MHS ribbed extension v-grooved
blade holder style 12
7" fluted with guarded switch hole
SPST latching guarded switch
luxeon 10 degrees lens and holder
covertec
thumb screw 8-32
Luxeon 3w driver V2 (latching)
clash sensor
i guess i need to know how much power i need to run it all (e.g. 4AA battery holder?/9v battery?) i think i read somewhere on the forum that it needs more than 6v to get the shimmer effect working. im not looking at sound at the moment, just want the shimmer/flicker effect and fade up/down effect.
4-AA battery holder is fine with regular alkaline batteries.
i dont think i need a resister at all with the driver (please correct me if i'm wrong) but may need a regulator? (if so, what kind and where can i get one?)
No resistor req'd. That's is what the driver is for. It regulates both the current and the voltage for the led.
is latching the way to go? or should it be momentary switch with the driver?
You can use either one as long as the driver board is the same type as the switch you want to use. If you think that later on, you'd like to use an MR board with it for sound effects, then stick with the latching switch/latching driver board combo.
anyhoo, thanks in advance for your help
