Hey Iam new to saber building and I wanted to use the modular wiring system. Have I selected compatible parts I've read and reread the descriptions but I am still confused http://www.thecustomsabershop.com/Vi...7-cfb82a72e4c3
Printable View
The modular wiring system is designed to go inside the Mhs parts sold at the shop
http://www.thecustomsabershop.com/Mo...tem-V1-C3.aspx
Other than that,I would recommend the recharge port as well
http://www.thecustomsabershop.com/MW...Port-P877.aspx
Yes I understand that I mean will the power pack work with the led and nano biscotti board etc
With the 2AA holder, you will need a single 14500 sized li-ion cell and a dummy cell. The Nano Biscotte will burn up if you put two li-ion cells in it, and 2 AA alkaline cells will not give enough power to run it.
You will also need a resistor for your main LED. The resistor will depend on the specific LED you have chosen.
Awesome thanks. Could I run it with two li-ions if I had a larger resistor or no?
The only thing you could do with that is make more heat.
No. The resistor is there to protect your LED, but it won't save the sound board. The NB was designed to run on a single li-ion cell. Two will cook it.
On the plus side, if you get a pair of 14500 cells, you can use one as a spare for when the primary needs recharging.
