Clean up the wires as best I could, not pretty but this is only my third saber and I'm more about function but I know other guys have their wires look all neat and clean and professional looking, mine will not be confused with a professional but they work so I'm happy with them. Plus, from a character point of view Kylo definitely takes after his dad and there are all kinds of wires everywhere on the Falcon, so I'm just following canon ;-)
Attachment 17272
I also mounted and glued the switch into the chassis, I cut out a small piece of plastic from and old dvd case and used it as a backer for the switch to give me more surface area to glue to.
Attachment 17273
Next up is the body plates, I actually spent a lot of time on my first build testing out hinges and such for the reveal section but nothing worked so I ended up going to the tried and true solution - DUCT TAPE, and I'm doing it again for this build. I actually just use a piece of black duct tape to join the two plates into a clamshell. Where the "hing" is, I have a thin strip of black electrical tape facing out so the seam isn't visible. It actually works great, and again since the theme of this post is - it ain't pretty but it's functional here it is.
Attachment 17274
I glued the back plate in place and need to wait for it to set completely, but once it does it works great, there's enough flexibility in the tape to manuever the cover but having one side fixed the reveal cover actually stays closed pretty well even with the few magnets.
Attachment 17275
Attachment 17276
I also got the 2nd battery put in place, unfortunately it sits a little high on the bottom side I'll need to create a cut out on the inner silver cover or omit it, but it fits in there and the top portion is a nice fit and holds the battery in place to prevent it from trying to drop out.
Attachment 17277
It is very tight, and with my fat fingers I am not actually toggling the switch with my fingers, I kinda knew this going in, but since I need the allen wrench for the blade set screws, it will also double as the switch toggle, it works like a charm.
Attachment 17278
I'm letting the back plate glue take overnight and then tomorrow I'll start looking at the wire clips, red wire and blue wires, etc.
