Hello, I what to have built a TPM OWK saber.
I need help in finding a Saber smith to do the work.
I saw a couple on you tube.
Can you guys help me out.
Thanks, Mauijedi
Printable View
Thanks, Mauijedi
Unfortunately, there is no selling or offering of services allowed on this Forum, as it's attached to store that caters to the Do-it-yourself crowd. I would highly recommend going over to either FX-Sabers or The Rebel Armory Forums, and checking there. THe hilts have been done before, so you might even find a compelted one for sale floating around in one of those spots.
Hey @mauijedi ! Welcome to the Forum!
You could get sort of close to the look of Obi-Wan's Lightsaber in The Phantom Menace with these parts, a hacksaw, a drill, and a flat bastard file...
1. MHSV1 Blade Holder Style 16----------------------------http://www.thecustomsabershop.com/MH...e-16-P416.aspx
2. 3" Double female threaded connector--------------------http://www.thecustomsabershop.com/3-...ctor-P122.aspx
3. Double ended male threaded connector style 1-----------http://www.thecustomsabershop.com/Do...le-1-P127.aspx
4. MHS ribbed extension-----------------------------------http://www.thecustomsabershop.com/MH...sion-P245.aspx
5. 1.2" Double Female--------------------------------------http://www.thecustomsabershop.com/12...male-P398.aspx
6. Cube Ring for Pommel Style 4----------------------------http://www.thecustomsabershop.com/Cu...e-4-P1072.aspx
7. Pommel style 4------------------------------------------http://www.thecustomsabershop.com/Po...e-4-P1071.aspx
8. MHS Sleeve material - 18"-------------------------------http://www.thecustomsabershop.com/MH...-18-P1167.aspx
9. 8-32 x 3/8" Stainless Steel thumb screw-----------------http://www.thecustomsabershop.com/8-...crew-P538.aspx
10. 8-32 x .3" red thumb screw-----------------------------http://www.thecustomsabershop.com/8-...crew-P547.aspx
11. 8-32 Covertec Button Thumbscrew---------------------http://www.thecustomsabershop.com/8-...crew-P825.aspx
12. Red LED indicator--------------------------------------http://www.thecustomsabershop.com/Re...ator-P114.aspx
13. SPST Momentary tactile switch-------------------------http://www.thecustomsabershop.com/SPST-Momentary-tactile-switch-P641.aspx
The idea here is that you would use two sections of the MHS Sleeve Material to cover over the MHS Ribbed Extension and the MHSV1 Blade Holder Style 16. You'll have to use a hacksaw and file to remove parts of the sleeve material in order to emulate the grip and emitter coverings on the Obi-Wan TPM Lightsaber.
Then drill out the holes required for the Thumbscrews, the Red LED Indicator, and the SPST Momentary Tactile Switch.
If you want to have a blade, and sound, you'll have to choose your sound card, speaker, speaker holder, battery pack, battery holder, chassis parts, etc.
I saved an image of these parts (those that are in the MHS Builder anyway) assembled so that you could get an idea for what it would look like, but this forum still won't let me post images. I just don't know why!
You can open up the MHS Builder here..............http://forums.thecustomsabershop.com...r.php?tabid=38
Find each part 1,2,3,4,5 and align/assemble them from right to left starting at the 11.5" mark on the ruler at the bottom of the Builder. You can substitute MHS Pommel 4 at the 0.0" mark to get a rough idea of the overall length that the lightsaber hilt will be with these parts.
I hope this helps you! Good Luck! And remember, it's way more fun to try and build your own lightsaber. Besides, how will you ever become more than just a Padawan if you don't build your own lightsaber? ;)
Hey @mauijedi !
I made a post for you over at TheRPF so that you could see the image of all of these parts together!
Head on over and join up to see the image!
mauijedi is available there, if you sign up with that as your membername you'll instantly have a "mention" that will link you directly to my post for you!
Or just click here..... https://www.therpf.com/showthread.ph...73#post4379873
Thanks!!!
Another option would be a hilt kit from the shop http://www.thecustomsabershop.com/OW...it--P1175.aspx
