TFN repost:
Okay, I still don't think this would look too hot. They are two different ideas of lighting, one in the blade and one in the hilt...
BUT I have an idea that will save you a butt load of work. [:)] A luxeon is not the greatest for this application. It will add heatsinking and the optics. The EL would be in the way also.
Idea: make a mount that uses the mono jack in the middle and a ring of smaller LED's (say 5mm) around it. This eliminates the optics, heatsinking, and the EL "being in the way". It also would overcome the trouble of the voltage of a 9V being bad for a Lux.
So basically make a dual-tube setup of inner white EL and then an outer tube (maybe a film diffuser?) lighted by the ring of small colored LEDs. Test it and get pictures. [:D]
<center>Read the FAQ or x-wing won't be happy. :(
http://img508.imageshack.us/img508/6703/xwing8az.gif</center>
