Wiring diagram for a NBV4 with extender?
Hi guys,
Finally got all the material (and time available, so I started the build.
I did mount the LED and the inner frame, The battery is in and I did put together the recharge port; so now I have basically all the wires ready to connect the board.
- Speaker wires
- Activation button wires
- Accent LED wires
- main LED wires (3 + 1 for the ground, which I tied together So I have one wire coming in from the LED assembly)
- Power wires coming from the recharge port.
Connection should be straightforward, since I tie all the negative together, which goes to the negative pad of the board; speaker wires go to the speaker pads, the activation button to the activation pad, and the accent LED goes to the small pad in the middle of the board (the one marked for the accent LED in various diagrams, not the 3.3V pad, otherwise I need the kill key because that LED would suck up the battery even when the board is turned off)
Now, from my understanding, the extender goes on the 3rd pad, which is the one used for the FOC feature; although I am not sure about how to connect it; does anyone have a pre-made working schematic that I can look at, to get an idea? Thanks!
